What fuel/brake SS hose?
#1
Posted 07 March 2012 - 05:10 PM
What hose is best for fuel and brake lines, you can get rubber or teflon with steel braid, but what one is best for a fuel and brake system.
I was even thinking of just running rubber fuel lines without braid, and then good braided line for the brake to prevent for expansion.
Is good braided line going to be better than copper?
Anyone know where to get good hose from?
Thanks
Sam
#3
Posted 07 March 2012 - 07:20 PM
But i can't have rubber lines as MSA regs state fuel lines inside the vehicle have to be protected with steel braid.
Pirtek seem to sell some braided that are good for fuel and made from teflon, but i want to know more before i decided about both.
Thanks
Sam
#4
Posted 07 March 2012 - 07:37 PM
Also, copper pipe is not very good, better off using kunifer pipe.
liberationists and Jackie Onassis blowing her nose. The theme song will not be written by Jim Webb,
Francis Scott Key, nor sung by Glen Campbell, Tom Jones, Johnny Cash, Englebert Humperdink, or the Rare Earth.
The revolution will not be televised.
#5
Posted 07 March 2012 - 08:28 PM
Thanks
Sam
#6
Posted 07 March 2012 - 08:55 PM
#8
Posted 08 March 2012 - 09:47 AM
#9
Posted 08 March 2012 - 01:59 PM
Yeah i thought this also, surely it can't be as good as copper or other hard line, but loads of race cars use it.
Thanks
Sam
#11
Posted 09 March 2012 - 12:52 PM
#13
Posted 09 March 2012 - 02:28 PM
Blackadder, on 09 March 2012 - 02:24 PM, said:
Are they not the bits on the end of the hose??? Maybe im getting confused, its Friday after all and my brain did stop working at 5pm yesterday.<div><br></div><div>Edit : A quick google search would just suggest they are just called hose ends! Unions are what's used on solid pipes.
</div>
#14
Posted 09 March 2012 - 06:49 PM
Also you can not use worm drive type clips on the teflon briaded hose, you need to use special olive tyre ends.
I've been told that the Goodridge 600 series briaded hose wont get expansion, so i would imagine good quality hose won't also.
Thanks
Sam
#16
Posted 09 March 2012 - 07:16 PM
Thanks
Sam
#17
Posted 12 March 2012 - 11:48 PM
#18
Posted 13 March 2012 - 08:54 AM
Iain, on 12 March 2012 - 11:48 PM, said:
It took me a second or 2 to figure out what you were on about then (it is early), but yes i see how this completely makes sense!
#19
Posted 13 March 2012 - 08:59 AM
Simonlpearce, on 13 March 2012 - 08:54 AM, said:
I accidentally made up a hos with two solid fittings at the weekend to go from a bias adjuster to a T piece, it was a complete nause, and i am still not happy with it now. Its fine if you are attaching to a union as the union will rotate.
#20
Posted 13 March 2012 - 11:57 AM
Iain, on 13 March 2012 - 08:59 AM, said:
Can i ask what you use to connect the hose ends? I thought some kind of industrial press was required in order to get a seal that will not fail under pressure???
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
