Jump to content
Welcome!
Sign In or Register to gain full access to our forums.
The slightly wannabe E36 Touring
  • Please log in to reply
89 replies to this topic
#81 pbmwBen
pbmwBen
    Advanced Member
  • Members
  • PipPipPip
  • 110 posts
Posted 15 January 2014 - 01:02 PM
Small update, these new wheel nuts arrived for me on Monday. They're Motorsport Hardware 'Titan' steel alloy extended nuts, should make it even easier to get wheels on and off. Plus they look really cool. Got them from UK MH master dealer Elite Developments.
Posted Image
#82 pbmwBen
pbmwBen
    Advanced Member
  • Members
  • PipPipPip
  • 110 posts
Posted 20 January 2014 - 12:58 PM
I've had a small coolant leak for a little while on the Touring and what with the cold temperatures, the constant expense of antifreeze it's something I've been meaning to sort for a while. I've had a look several times and it wasn't obvious, but last week the temperature gauge started playing silly beggars and the coolant use went up several fold.
Because of that, I finally got my act together and went about locating the leak. Ran the car up to temperature and could see coolant leaking underneath but with no obvious source. Found it in the end - it's the connector that bolts onto the heater matrix pipes and pokes through the bulkhead/firewall. Bit of a pain as I was hoping I wouldn't have to visit the stealers, but oh well. Part number 11 below.
Posted Image
Getting to it involves taking a fair bit of the engine bay apart. Luckily I don't have an airbox in the way though. Looked pretty sorry for itself when I started:
Posted Image
You can't really see, but it's under this lot.
Posted Image
This is the bit - you can just about see the crack, which means the pipe no longer fits snugly into it and therefore, leaks everywhere.
Posted Image
Going to get all-new parts from the dealer to avoid more issues with brittle plastic. Also going to look at replacing the heater hoses with silicone just in case they decide to have any kind of wobbly. Other than that, I just need to get everything sorted for our trackday at Brands Hatch on Feb 24th!
#83 pbmwBen
pbmwBen
    Advanced Member
  • Members
  • PipPipPip
  • 110 posts
Posted 24 January 2014 - 02:27 PM
Just finally got round to getting the build sheet for the Touring, been meaning to get one for ages. As I suspected, it's basically a Sport with no other extra - :lol:
Posted Image
Have also ordered all the heater bits and have booked the day off next Wednesday to fix it all. Genuine coolant and a new Vanos microfilter also ordered.
#84 pbmwBen
pbmwBen
    Advanced Member
  • Members
  • PipPipPip
  • 110 posts
Posted 27 January 2014 - 02:36 PM
The Touring is 15 years old today. Yay.
Unfortunately it's sitting at home broken, so rather than taking it for a celebratory drive I'm just going to have to put up a picture of it. This was the first time I had it out on track at the PBMW track evening a couple of years ago, at Brands Hatch. Under M52 power at the time.
Posted Image
We have a track day coming up on Feb 24th at Brands again. £139 for a whole day of open pit lane - check it out below. See you there!
http://www.clubmsv.co.uk/pbmw
#85 pbmwBen
pbmwBen
    Advanced Member
  • Members
  • PipPipPip
  • 110 posts
Posted 30 January 2014 - 09:54 AM
Spent yesterday doing some repair and maintenance.
First up, replaced the broken heater connector. Not too bad-a-job, filled it up with Genuine coolant, bled it out and it was good to go. No more leaks and no more overheating! The heater also works better now that it's getting some pressure through it.
Posted Image
All back together
Posted Image
Then did my Vanos microfilter and o-rings. The filter looked alright but the lower o-ring (small black one) had just gone hard and clearly wasn't sealing properly. Replaced the bits, put it back in and the Touring is good to go again. I'm not sure if it's placebo effect but it also seems to pull more aggressively. It's that or the fact I haven't driven it for a couple of weeks - either way, I sh*t my pants when I put my foot down!
Posted Image
Now the fuel gauge seems a bit suspect at times and this morning, my indicators stopped working. Brilliant.
#86 pbmwBen
pbmwBen
    Advanced Member
  • Members
  • PipPipPip
  • 110 posts
Posted 04 February 2014 - 02:45 PM
Not much of an update about the car as such, just a few other bits.
Firstly, new indicator relay has turned up so will throw that in and hopefully fix the issues with that.
Posted Image
Will also chuck this in the window at the same time. It's now been under S54 power for 6 months, don't know where the time has gone.
Posted Image
Fitted my old aFe induction kit to a friend's new 323i. Went for a spin in it and it made me realise how savage the S54 is compared to my old M52.
Posted Image
Paul46 text me the other day to say that my rear calipers are ready, so looking forward to getting those on Sunday. The rear kit uses 4-pot calipers and 336mm discs but came as an E34 M5 kit with red calipers. Now the colour has been corrected, I'll have to work out what needs doing with the brackets for fitment. As the discs are transferrable I'm partially hoping that the bracket will be the same or close to it.
Posted Image
Ran these to the tyre shop this morning, getting them shod ready for their new home. They're 8.5 and 10x18 with 215/40 and 225/35 tyres if I remember rightly - should be a nice challenge for the tyre fitters. Really not looking forward to seeing these go but will be grabbing a few shots back on the Touring before they leave my grasp.
Posted Image
Posted Image
And finally, haven't been able to stop myself researching things like this. Oops.
Posted Image
#87 pbmwBen
pbmwBen
    Advanced Member
  • Members
  • PipPipPip
  • 110 posts
Posted 09 February 2014 - 06:13 PM
Right, I have a pretty serious problem.
As mentioned previously my fuel gauge seemed a little dicky. Now I have no coolant temp, no oil temp and the fuel gauge doesn't really work - most of the time it's dead, but occasionally slowly rises to around 1/3 of a tank then drops again. Fuel light is on when the needle is in the right area. Illumination works, speedo is unplugged at the diff at the moment (long story) so can't way whether that works.
I've checked the fuses and can't see anything wrong, tried different clocks and no luck there either. Anyone got any ideas?
The car has also blown an indicator relay recently if anyone thinks that's related. Bad earth?
#88 pbmwBen
pbmwBen
    Advanced Member
  • Members
  • PipPipPip
  • 110 posts
Posted 14 February 2014 - 09:54 AM
Fixed!
Posted Image
Unfortunately I have less fuel than I was hoping, but apart from that, seems perfect. Need to go for a longer drive and see if the fuel gauge still wanders around like it did before, but it seemed ok lastnight.
Turns out it was just a couple of fuses which looked ok but had broken inside somewhere :lol:
#89 pbmwBen
pbmwBen
    Advanced Member
  • Members
  • PipPipPip
  • 110 posts
Posted 17 February 2014 - 12:02 PM
Had a busy weekend. For starters, went out flood-wading in my friend's Landy 110. Got a little too brave but luckily the only dramas were water-filled headlights and blown bulbs. This is a road I usually cycle on.
Posted Image
The set about finding what was up with my indicators, as a few checks suggested the relay wasn't to fault. Didn't take long - tyre has gone through the wiring.
Posted Image
Fresh wiring, which I tucked down inside the chassis bar
Posted Image
Will do the other side the same when I have time. Indicators now fully working. Last thing to do was to trim down my rear brake dust shields, ready for the WP Pro kit to go on. Just waiting on the machine shop to finish skimming my brackets, which I needed to do as the kit is an E34 M5 one.
Posted Image
#90 pbmwBen
pbmwBen
    Advanced Member
  • Members
  • PipPipPip
  • 110 posts
Posted 25 February 2014 - 02:50 PM
Had yesterday at the PBMW trackday, which was pretty awesome.
I'd been waiting on brake pads for some time - I talk to Sam at WP Pro a lot and there had been a muck-up on the order before and so he sent the first set from the next batch they had available. Also, because of the mistake being on his end, he sent it two-day delivery from Canada, which I was impressed by as it can't have been cheap.
Anyway, I'd been checking TNT tracking as Sam had supplied me the consignment number and to my surprise, it ended up sitting at Heathrow for 4 days. It should have arrived last Wednesday, instead they arrived at my offices (just down the road from Brands, luckily) only yesterday. So I did my sighting laps, nipped to the office to grab the pads, and set about fitting them just behind the pitlane.
Pleased to report that despite tons of miles of service (I think around 30k since I've had the brakes) the pads had worn evenly and all the pistons moved freely. So getting the new pads in was nice and easy. I did a bit of bedding in with a quick run up and down the road (WP's pads don't need much bedding in at all) and then I hit the track. Only to find that the small vibration I'd had before soon turned into quite an alarming vibration.
A few quick checks and one of my track rod ends had completely given up, with the other not far behind. Great! This was another thing that was supposed to be changed before the track day but wasn't - long story. Quick phone call to a couple of local factors and one had the pair in stock, which I collected straight away and fitted trackside. I say me, but actually a mate had come along for the day with me and ended up doing most of the work because loads of people wanted to talk to me!
Anyway, pics:
Posted Image
Posted Image
Posted Image
Posted Image
In the end it did me proud - still have a few issues to resolve (slight vibration, massive fuel starvation, bit of a long brake pedal, need to get a Sport button to take it off sport mode, gearing is way too long) but it's fast, handling is good though a bit soft and the engine was faultless.
A couple of people put cameras in my car - this is the footage from one of them, which was Jonny from Car Promo's gear.
http://www.youtube.com/watch?v=Kj8o4ntkwBg
And this is Rob from RAW taking it out
http://www.youtube.com/watch?v=scSC5FZBtRg
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
